Carlos Simões 0 Report post Posted April 10, 2023 Hello, I was following a tutorial on fully parametric hull model generation, but I reached a dead end. Nevertheless, I don't want to lose my work. As you can see from the attached file, I've generated all geometric curves and they are fixed (there's no parameters used). How can I proceed from that? I need to create the sections with some parameters (like the flare) that will vary, and then generate the surfaces. How can I do it? Is there any tutorials that can help me? Best regards, Carlos newcastlemax_model2.cdbc Share this post Link to post Share on other sites
Ceyhan Erdem 14 Report post Posted April 11, 2023 Hi Carlos, I will highly recommend you perform the basic tutorials with regards to parametric geometry creation. Under; Tutorials > Basics You can find the necessary tutorials/information on how to proceed in your model. Cheers Ceyhan Share this post Link to post Share on other sites
