Mr. Humberto Nakanishi 0 Report post Posted February 25, 2014 Hello,I would like to export a panel mesh (.pan) object with more decimal cases then the default configuration. Does anyone know if it is possible?Cheers,Humberto Share this post Link to post Share on other sites
Mr. Arne Bergmann 27 Report post Posted February 26, 2014 Hi Humberto, You can write a feature that does the export for you. That way you have full control over the number decimals that are written to the file. Both, the FDouble.toString() command and the global asString() commands, take the precision as an argument: |> (8.123456791234).toString("g", 14) "8.1234567891234" |> asString(8.123456791234, 0, 14) "8.1234567891234" For an example of how to write an export feature, see the following post that includes a project where panel meshes are exported: http://www.friendship-systems.com/forum/index.php?/topic/159-exporting-custom-file-formats-using-features/ Hope this helps. Arne Share this post Link to post Share on other sites
Mr. Humberto Nakanishi 0 Report post Posted February 26, 2014 Hi Arne,Yes, it solves my problem.thanks,Humberto Share this post Link to post Share on other sites
