Sign in to follow this
Matthias Maasch
Airplane wing with winglet
please find attached an airplane wing. The wing is created with a flexible metasurface. At the tip of the wing you can find a winglet.
In the gif-file below I visualized a parameter selection.
The scope "01Base" includes the initial profil setup which is inside the feature definition. In the scope "04Parameters" you can find the usual paramaters for
  • chord length
  • span
  • sweep
  • thickness
  • camber ...
Furthermore you can find some parameters to control the winglet. You can change all the functions to your needs. So you can create a lot of wing and winglet types.
Matthias
wing.fdb
