Mr. Hongdan Wang 0 Report post Posted October 23, 2013 Hi I am doing the toturial of Basic preprocessing. And I account a surface generated problem when I am generating the ruled surface of the tip of the wing. The problem is that it can not generate the surface when i have choosen the pressure profile and the the root profile of the tip surface. It gave below informantion: *** INFO |s1 : can not generate reasonable surface by means of the given input curves how could i generate the tip surface of the wing Share this post Link to post Share on other sites
Mr. Adjei Richard__0001 3 Report post Posted October 23, 2013 hi, I also faced similar problems when I started working with FFW. Please check the domains of the image curves again (suction side and pressure side). it should be [0,0.5] and [1,0.5] not [0.5,1] Hope this helps. Share this post Link to post Share on other sites
Mr. Hongdan Wang 0 Report post Posted October 23, 2013 hi, I also faced similar problems when I started working with FFW. Please check the domains of the image curves again (suction side and pressure side). it should be [0,0.5] and [1,0.5] not [0.5,1] Hope this helps. Yes it works now, thanks very much! Share this post Link to post Share on other sites
Ms. kim howes 0 Report post Posted December 16, 2013 Hi i am having problems offsetting the tip along the Z by 2 - nothing happens any advise? Share this post Link to post Share on other sites
Karsten Wenzke 12 Report post Posted December 16, 2013 Hi Kim, can you attach the project file than it is easier for us to help you. We can than send you an edited version. I've created an offsetcurve of a profile and an offsetsurface of a wing. Please see the attached pictures and project. Does this solve your problem? Best Regards Karsten profileOffset.fdb Share this post Link to post Share on other sites
