Sign in to follow this
Mr. mohamad gh
marine propeller optimizaion using cfd
hi freinds ............ i am a graduate student. i want optimize a marine propeller using CFD . propeller type is HSP(high skewed propeller)
. I do not know much about it. I just want to do it with CAESES and STARCCM+ softwaresoffset-HSP.pdf .
please help me.   thanksss........
http://s6.picofile.com/file/8237470934/offset_HSP.xls.html
Hi Mohamad,
In order to get started with CAESES you should go through our tutorials. You can find the tutorials in the Documentation Browser. Depending on your CAESES knowledge you could go through all tutorials in the "Content of Getting Started" section. Once you are familiar with the basic techniques of modelling, pre-processing and post-processing in CAESES, you could go on with the tutorial "Generic Blade" in the "Content of Blade Design" section. This will allow you to model the propeller blade which is described in the xls sheet you attached.
Finally you could have a look into the tutorial "S-Duct with Starccm+" in the "Content of Integrations" section. This will show you how to connect CAESES and Starccm+.
I hope those suggestions will help you to get started.
If you have further do not hesitate to post them!
Best Regards
Matthias
