Mr. sabah alwan 0 Report post Posted January 14, 2014 Folks, Is there a possibility to control FRIENDSHIP System software externally or link it to other inhouse software? I am planning to pilot it from Matlab (feed in some parameters, test some algorithms), read the results and link it to other inhosue software. Much appreciate your thoughts on this. Cheers,Sabah Alwan Share this post Link to post Share on other sites
Stefan Wunderlich 6 Report post Posted January 15, 2014 Hi Saban,In general, CAESES-FFW does not provide a COM-interface or anything similar to interact with it from another program at runtime.Matlab provides methodes to execute system calls (check here) so you might want to run CAESES-FFW with a script file as argument. So you could, have Matlab generate such a script file (*.fsc). Inside the script, you can use the command interface of CAESES-FFW (i.e. openProject("path_to_project"), set values, export geometry or generate custom exports within features). For a short introduction to the script files, start CAESES-FFW, open the "Global Commands" page in the Documentation Browser and look for the "source(FString)" command (e.g. Ctrl+F, type "source(F"). Cheers,Stefan Share this post Link to post Share on other sites
Mr. Humberto Nakanishi 0 Report post Posted February 24, 2014 Hello Sabah,I've already done it in the past.Basically I run a configuration m-file that open the Framework in batch mode.Then I use another file to control it using the send.keys commands (in Windows).I will send you the files. Just ask me if you need.Cheers,Humberto 1st the configuration file %% Configuration of the Matlab to run Friendship on Batch Mode % Configure Matlab Classes configuration % Desactivate warning messages warning('off') % Import Power Shell Class h = actxserver('WScript.Shell'); % Open Framework on batch % dos('FrameworkBatch.bat&'); % pause(20) global control % Create the object to Control the FFramework control = ControlFFramework(); % Open Project h.AppActivate('C:\Windows\system32\cmd.exe'); command = ['openProject{(}{"}' control.ffFile '{"}{)}{enter}']; h.SendKeys(command); global design design = PlaningShip_v11(); design.Bmax = 2*1.985; design.Vk = 31; design.CG = [0 1.406]; design.f = 0.578; design.eps = 8; design.Hs = 0.55; design.Loa = 12.37; design.Lpp = 12.37; design.opCond = 'oper'; design.calcSlam = false; design.Dp = 0.63; design.P_D = 1.238; design.EAR = 0.85; design.Z = 4; design.Np = 2; design.propSeries = 'SeriesB'; design.useRaw = false; design.etaR = 0.95; design.cavCriteria = 'BackCav10'; design.Nwtb = 2; design.waterCap = 500; design.fuelCap = 1100; design.nPas = 14; design.useEngine = true; design.engName = 'VolvoD6_435'; % Ap0 = 33; % Dt0 = 0.457; % intVol0 = 53.5; % LCB0 = 0.4588; % BxMaxDeck = 1.98; % LOA = 12.37; And now the Framework Controller %------------------------------------------------------------------------ % ControlFFramework % %------------------------------------------------------------------------ % Makes the comunication between Matlab and the FRIENDSHIP-Framework. classdef ControlFFramework %% Public properties properties % Variables vector % v(1) - alphaCenter % v(2) - Dstern % v(3) - Dbow % v(4) - xBase % v(5) - alphaChine % v(6) - BxLin % v(7) - Bxt % v(8) - CAp % v(9) - Dt % v(10) - ie % v(11) - xLin % v(12) - alphaBotF % v(13) - alphaBot0 % v(14) - xPos % v(15) - deadxLin % v(16) - deadt % v(17) - deadLp % v(18) - H % v(19) - Lp % v(20) - sca0 % v(21) - scaF varVec end %% Calculated Properties properties (SetAccess = private) FFParameters FFConstraints % FFramework file ffFile end %% Private porperties properties (SetAccess = private, GetAccess = public) % Frienship Server ffServer % Result file template resultTemplate constTemplate dummyFile varTemplate % Basys ship variables basysVarVec = [41 0.10 2.0106 9.1 11 3.339 3.118 0.905 0.457 40 4.664 25 0 7.5 15.55 11.54 45 0.875 11.44 0.9 0.9]; end %% Constructor methods function obj = ControlFFramework(myVarVec) % Creates an ControlFFramework object % function obj = ControlFFramework(myVarVec) % - myVarVec: variables vector if nargin == 1 obj.varVec = myVarVec; else obj.varVec = zeros(1,21); end obj.ffServer = actxserver('WScript.Shell'); [name, patch] = uigetfile({'*.fdb'},'Select the FFramework file'); obj.ffFile = [patch name]; obj.varTemplate = [patch 'variables.txt']; aux = [patch regexprep(name,'.fdb','') '\manual_results\baseline']; obj.resultTemplate = [aux '\results.txt']; obj.constTemplate = [aux '\constraints.txt']; obj.dummyFile = [aux '\finished.txt']; end end %% Setters and Getters methods function obj = set.varVec(obj,myVarVec) test = size(myVarVec); if test(1) == 21 || test(2) == 21 obj.varVec = myVarVec; else warning('Parameters:WrongRange','The size of varVec is not correct!') end end end %% Public Methods methods function result = sendVarVec(obj) % function result = obj.sendVarVec() % Export the variabkes to the FFramewor and force to project to % update % Delete template files delete(obj.resultTemplate) delete(obj.constTemplate) delete(obj.dummyFile) % export variables File saveVarVec(obj.varVec,obj.varTemplate); obj.ffServer.AppActivate('C:\Windows\system32\cmd.exe'); obj.ffServer.SendKeys('|variables.run{(}{)}{enter}'); obj.ffServer.SendKeys('|export.run{(}{)}{enter}'); obj.ffServer.SendKeys('getCurrentVariant{(}{)}.reduce{(}{)}{enter}'); result = 'completed'; end function closeProject(obj) % function result = obj.sendVarVec() % Export the variabkes to the FFramewor and force to project to % update obj.ffServer.AppActivate('C:\Windows\system32\cmd.exe'); obj.ffServer.SendKeys('closeProject{(}{)}{enter}'); obj.ffServer.SendKeys('n{enter}'); obj.ffServer.SendKeys('exit{enter}'); pause(10); obj.ffServer.SendKeys('exit{enter}'); end function obj = readResultFiles(obj) % function obj = obj.readResultFile() % Reads the geometric and hydrostatic result file create by the % FFramework. Also read the file with the constraints calculate % by the FF. fid = -1; while fid == -1 fid = fopen(obj.dummyFile); end fclose(fid); obj.FFParameters = readFile(obj.resultTemplate); obj.FFConstraints = readFile(obj.constTemplate); end function obj = setBasysHull(obj) % function obj = setBasysHull(obj) % Set the basys hull variables obj.varVec = obj.basysVarVec; obj.sendVarVec(); end end end function read = readFile(fileName) % function read = readFile(fileName) % Read the file fileName fid = fopen(fileName); read = ''; % Positionate the file pointer while ~strcmp(read,'Start') read = fscanf(fid,'%s',1); end % Read parameters read = fscanf(fid,'%f',inf); % Close file fclose(fid); end function saveVarVec(varVec, fileName) label = 'alphaCenter Dstern Dbow xBase alphaChine BxLin Bxt CAp Dt ie xLin alphaBotF alphaBot0 xPos deadxLin deadt deadLp H Lp sca0 scaF'; fid = fopen(fileName,'w'); fprintf(fid,'%s\n\n',label); fprintf(fid,'%g ',varVec); fclose(fid); end Share this post Link to post Share on other sites
Mr. Marek Nowaczewski 0 Report post Posted March 24, 2014 Hi everybody,as far as I can figure out the usage of scripts is not available in CEASES as described by Stefan.It was a bit confusing for me. Cheers,Marek Share this post Link to post Share on other sites
Mr. Konrad Lorentz 2 Report post Posted October 2, 2014 Hi Marek, fsc scripting is a feature of CAESES Pro / FRIENDSHIP-Framework, not of CAESES Free. If you are a student, you may apply for a free license. RegardsKonrad Share this post Link to post Share on other sites
Mr. Hairul Ahmad 0 Report post Posted May 22, 2016 Hi Sir, I am new to CAESES framework. I would like some advice/teaching on how to run CAESES in Batch Mode. Thank you. Share this post Link to post Share on other sites
