Mr. Ashesh Pradhan 0 Report post Posted June 5, 2019 We can make a multi-segmented smooth curve from Feature Definitions -> Hull Design -> Multi Segmented Smooth Curve. The issue is I can only define '2' intermediate points in a curve. I want to join many multi-segmented curves to create a single curve. How do I do it ?I am a beginner in CAESES. I could not find it in documentation. Please help. Share this post Link to post Share on other sites
Jörg 29 Report post Posted June 5, 2019 Hi Ashesh, Basically, there are many ways to create a curve through points with some more controls. For instance, you can use a 2D interpolation curve where you can optionally set angle conditions for the input points: Note the list entries e.g. [p2,0] => [point, angle]. One could also think about modifying this existing feature, to allow users taking into account an arbitrary number of input points. If you tell a bit more about what you want to do, I (or others) can probably give more recommendations. CheersJörg Share this post Link to post Share on other sites
Guest Report post Posted June 12, 2020 Dear Jörg, although this might be an old request, I have more or less the same question. I'd like to create a CPC of a container ship including bulbous bow, hence need approx. 5 intermediate points or an alternative curve. The idea is to design a ship hull according to the set-up of the fastmonohull tutorial. Is the above mentioned 2D Interpolation curve suitable or would you suggest using a different one? Br Matt Share this post Link to post Share on other sites
Mr. Claus Abt 14 Report post Posted August 31, 2020 HI Matthias, I would probably use a polycurve and assemble it from lines and curves depending on the individual needs of the particular region. Cheers Claus Share this post Link to post Share on other sites
