Mr. erkan ozdn 0 Report post Posted February 13, 2019 Hello; I tried to explain my issue as here below; Best Regards...Erkan Share this post Link to post Share on other sites
Ceyhan Erdem 14 Report post Posted February 13, 2019 Hi Erkan, I can see from the code that the operation to trim the geometry is the one starting from line 250.What you have to do is to change the input within the command".setSource()" so just create the surface that you desire to do the trimming before the fbrepsolidfromintersections operation and update the "setSource" respectively. Please let me know if you still have problems. I would also recommend you to go over the tutorials, once you have a basic understanding it may be easier to understand the samples. CheersCeyhan Share this post Link to post Share on other sites
Mr. erkan ozdn 0 Report post Posted February 13, 2019 Hi Ceyhan; I changed radius and location of the teRef2 and teRef1. Now i have tips but due to i have to cut blades with thickness of the hub. Hub edge is not flat. It has same angle cut. :( Please see attached file. Br...Erkan Share this post Link to post Share on other sites
Ceyhan Erdem 14 Report post Posted February 14, 2019 Hi Erkan, Please check the attached project. I have created two faces then added them to a BRep and used it for the fbrepsolidfromintersections operation.That can give you an idea how to approach such a problem. CheersCeyhantry.fdb Share this post Link to post Share on other sites
