Mr. Karl Hohenberg
Volute Tongue Modelling
I'm having some trouble generating a volute geometry, specifically the tongue area.
I have tried two different approaches but both don't give very clean results (see attached model). Does anyone have any ideas for how I could solve the problem?
Another issue I have encountered is that in one of my Breps which I have trimmed using a curved surface, the trim edge is subdivided into several straight edges (see attached image where one edge is selected) instead of one curved edge per surface. Does anyone know what the reason for this could be?
Many thanks!
Karl
Volute.fdbc
Hi Karl,
Can you please check the attached project file.
It is a quick approach and I didn't play much with it  but you can further develop it.
I have added two feature definitions;
- one for creating curve orientation consistency, f_revise_curves
- and the other for the tongue surface creation, f_tongue
Please check and let me know if you encounter any problems.
For your question about the subdivided trim edge, I would assume that there is tangency discontinuity which is causing the edge to be subdivided.
But you can easily get the trimmed edge group using the command,
your_BRep.getEdgeFrom(operation index where the trim happens)
Ceyhan
Volute2.fdbc
