Mr. Carsten Fuetterer 9 Report post Posted July 6, 2018 When your are missing your 3D Windows, there are different ways to recreate it: Reset CAESES to factory settings. Therefor go to file/settings:If this did not worked you can try to remove the stored configuration data in following folders: - Windows: %APPDATA/friendship/etc% - Linux: ~.friendship/etcyou can first look if you just closed it and if you can not find it you can easily create a new one: Share this post Link to post Share on other sites
Jörg 29 Report post Posted May 8, 2019 In some special cases we observed that only the CAESES restart works, using the "reset to factory settings" menu entry: Share this post Link to post Share on other sites
