Mr. Kim Moo Sung 0 Report post Posted May 31, 2018 Hi~ I run into a few problems... one thing is importing xml format file. I tried to apply what others had made to solve reading txt file. but i can`t solve just I want read one line in X, and next line is Y ex)xml file is<Value Type="Vector2" Index="0"><x Type="Float">0.547408021449596</x><y Type="Float">1.77333179937449</y></Value> and I want to create Point ( 0.547408021449596, 1.77333179937449, 0) other thing is separating line in xml file, 0~200 line is Curve1, and 201~400 line is Curve2... I create Curve1 that 0~400line is Can I get some help with this? thanks best regards Moo SungCFturbo_connect_readxml.zip Share this post Link to post Share on other sites
Ceyhan Erdem 14 Report post Posted June 1, 2018 Hi Kim, Please find attached the project with a feature that reads and plots your html data. CheersCeyhanCFturbo_connect_readxml.fdbc Share this post Link to post Share on other sites
Mr. Kim Moo Sung 0 Report post Posted June 4, 2018 Hi Ceyhan, Thank You!!! I learned a lot. Best regards Moo Sung Share this post Link to post Share on other sites
