Ms. lexi wang__0001
questions on exporting fully parametric model to rhino
I am now trying to export a fully parametric model to rhino.
But i have got lots of NURBS surfaces . ( Since we are doing some comparison work for T-spline in rhino and NURBS in caeses )
1.How can I directly export the surfaces from caeses to rhino?
2.when I export the local parametric bulb from caeses with stl.file to rhino that is fine.
Is this about the fully parametric model ?
3.Recently when I open the files i have got some tips on the model like in figure. question ,
How can I repair them?
4.When I am trying  to get the shaft_cut_tan in the figure.question2. I cannot make the
start and end point for Y=0, that is why i cannot close the shaft totally. How can I repair this
problem?
Thanks for your help!
Lexi.
Hi Lexi,
Is it possible that you share the project file if it is not confidential?
You can send the fdb/fdbc file to erdem@friendship-systems.com, so I can give a look.
Ceyhan
  1. Not sure what you mean. If you export the model using IGES or STEP, of course you will get all the surfaces that you have created within CAESES. Which export format did you use?
Is this a new behavior? For example, did it work with a previous CAESES version so that it is a compatibility issue?
1 I have a fully parametric model, i wanna export igs.file with surfaces to RHINO
2 There is no problem for transporting stl.file to use in starccm
3  I think that is always there
i will send the team erdem for a check .
Thank you for your help!
Ok, cool.
What is the problem with the IGES file? Usually we have no problems with exporting models to RHINO using the IGES format.
I guess the other things are really something where one have to look into it.
Hi Lexi,
Ceyhan
Hi
I have send you the file.
cheers,
Lexi.
Ok, cool.
I have send Ceyhan the file just now. Thanks for your help!
Lexi.
