Mr. Bram1 Kerkhofs1
2d drawing of brep
Hi
I was busy with checking if I could make a technical drawing from a brep.
In attachment I put a shape, and I would like to make a drawing out of it.
I tried to experiment with the 2D window a bit, and also with the FGIGeometry's that you get, but for now I can only make a drawing from a line, not from a surface or a brep.
Anybody an idea?
Thanks
Bram
2dWindow.fdbc
Hi Bram,
Yes you are right - the 2D-drawing functionality covers only curves, and sections (e.g. from a section group that are generated on surfaces and breps). For breps itself, we have not implemented it yet. This is a TODO on our list.
Here is a possible solution:
Some users write their own feature definitions in CAESES to visualize 2D-data in the 3D-window - and then export it to have some sort of custom 2D-drawing. For breps, you can loop the edges (command: brep.getEdge(...)) and use "dimension lines" (menu > visualization > linear dimension) to set up a 2D drawing. This is a bit of manual work (typing the stuff in a feature) but on the other hand it allows you to customize it fully to your needs.
Sorry for not having a faster solution available at the moment,
Hi Joerg
No problem,Thanks for the tip!
If I can make the drawing to scale, that would be already good :).
I put a working case in the attachment.
It basically gets all the lines from a brep and puts them in FGIGeometries and loads them into the screen.
Note: The input breps must be in between square brackets (as an objectlist)
Bram
2dWindow.fdbc
