Ms. Yanxin Feng 1 Report post Posted March 16, 2017 Hello everyone, I came across a problem when I run the software connections in new version CAESES 4.2.0. I connected CAESES with GLRankine, I already set up all the input files and output files. When I run the simulation in version CAESES 3.0.19, everything worked well and I could get the right "log.out" file and the "stdouterroroutput.redirect" recorded the right progess. However, when I just open the same project in version CAESES 4.2, I couldn't get the right "log.out" file. And the error showed as: "Error during steady computation: Could not create file 'data/steady_body0_1.vtk'." During the "stdouterroroutput.redirect" file, it showed that : Input move failure, using fallback method to move /home/feng/5415/newversion_caeses/4.2version_newparametricmodel/manual_results/baseline/42_GLR_test01/input/data to /home/feng/5415/newversion_caeses/4.2version_newparametricmodel/manual_results/baseline/42_GLR_test01//dataFailed: Cannot open /home/feng/5415/newversion_caeses/4.2version_newparametricmodel/manual_results/baseline/42_GLR_test01/input/data for input And the calculation could not run sucessfully. I hope I the way I already described my problems clearly enough. Please check the details from the attach files. Thanks in advance. Best Regards,Yanxin Feng4.2version_newparametricmodel.fdbcnewparametricmodel.fdbc Share this post Link to post Share on other sites
Jörg 29 Report post Posted March 17, 2017 Hi Yanxin, Hm, that's strange - we are not aware of such a problem with the latest version. I have to check with my colleagues. Best regardsJoerg Share this post Link to post Share on other sites
Ms. Yanxin Feng 1 Report post Posted March 17, 2017 Hi Joerg, thanks for your reply. I tried to upload the config.xml file and log.out file, but it was not allowed. Otherwise you could try to run my project on your pc.Have a nice weekend! Best Regards,Yanxin Share this post Link to post Share on other sites
Mr. Claus Abt 14 Report post Posted March 18, 2017 Dear Yanxin,It looks like you want to create a /data subdirectory in the runDir. That is obviously not done. Was there probably a batch file in the connector that had to be called prior to executing Rankine?Best regardsClaus Share this post Link to post Share on other sites
Ms. Yanxin Feng 1 Report post Posted March 20, 2017 Dear Yanxin,It looks like you want to create a /data subdirectory in the runDir. That is obviously not done. Was there probably a batch file in the connector that had to be called prior to executing Rankine?Best regardsClausDear Claus, Thanks for your reply. I created a txt file in the input files.And I edit the name of it as "data/MakeDataFolder".But it doesn't work in version CAESES 4.2.0. Or should I create the data folder in another way? Best Regards,Yanxin Share this post Link to post Share on other sites
Ms. Yanxin Feng 1 Report post Posted March 20, 2017 hello everyone, I followed the advice from Carsten and did it like this: -select the Runner-Go to Local Execution Settings and click on "show more options" (the three dots)-then toggel "clear Input Directory" It also works for me. Thanks a lot! Best regards,Yanxin Share this post Link to post Share on other sites
Ms. lexi wang__0001 0 Report post Posted April 20, 2017 hey guys, when i connect with STAR CCM+, I came across the problem with tips when do sybol optimization: *** INFO FGenIntReader : Could not open fileC:/Users/xdb14181/Desktop/FPM CAESES/Int/KCS_OPT1/01_Sobol/Sobol_01_des0005/Runner//Data.csv for reading [parsing process aborted]. could you please tell me what might be the problem with this? cheers Lexi Share this post Link to post Share on other sites
Ms. lexi wang__0001 0 Report post Posted April 25, 2017 Dear Yanxin,It looks like you want to create a /data subdirectory in the runDir. That is obviously not done. Was there probably a batch file in the connector that had to be called prior to executing Rankine?Best regardsClausHi Claus, when i connect FFW with STARCCM+, I have tips in redirect file as below. i wonder what is the problem with my license , for it works in my computer for STARCCM+. Cheers, Lexi. STAR-CCM+ 11.02.010 (win64/intel15.0-r8)License build date: 10 February 2015This version of the code requires license version 2016.02 or greater.Checking license file: 1999@name-server02Unable to list features for license file 1999@name-server02.Checking license file: 1999@flex.cd-adapco.comFailed to get all licenses needed for this job. Asked for 1 licenses of ccmpsuite"C:\Program Files\CD-adapco\STAR-CCM+11.02.010-R8\star\lib\win64\intel15.0-r8\lib\star-ccm+.exe" -cpubindMPI Application rank 0 exited before MPI_Finalize() with status 8"C:\Program Files\CD-adapco\STAR-CCM+11.02.010-R8\mpi\platform\9.1.4.0\windows\bin\mpirun.exe" -aff=automatic:bandwidth -np 1 "C:\Program Files\CD-adapco\STAR-CCM+11.02.010-R8\star\bin\starccm+.exe" -cpubind -nodeerror: Design STAR-CCM+ simulation completedServer process ended unexpectedly (return code 1)mpirun: Drive is not a network mapped - using local drive.MPI Application rank 0 exited before MPI_Finalize() with status 8 Share this post Link to post Share on other sites
Ms. lexi wang__0001 0 Report post Posted April 27, 2017 Dear Yanxin,It looks like you want to create a /data subdirectory in the runDir. That is obviously not done. Was there probably a batch file in the connector that had to be called prior to executing Rankine?Best regardsClausHi Claus, when i connect FFW with STARCCM+, I have tips in redirect file as below. i wonder what is the problem with my license , for it works in my computer for STARCCM+. Cheers, Lexi. STAR-CCM+ 11.02.010 (win64/intel15.0-r8)License build date: 10 February 2015This version of the code requires license version 2016.02 or greater.Checking license file: 1999@name-server02Unable to list features for license file 1999@name-server02.Checking license file: 1999@flex.cd-adapco.comFailed to get all licenses needed for this job. Asked for 1 licenses of ccmpsuite"C:\Program Files\CD-adapco\STAR-CCM+11.02.010-R8\star\lib\win64\intel15.0-r8\lib\star-ccm+.exe" -cpubindMPI Application rank 0 exited before MPI_Finalize() with status 8"C:\Program Files\CD-adapco\STAR-CCM+11.02.010-R8\mpi\platform\9.1.4.0\windows\bin\mpirun.exe" -aff=automatic:bandwidth -np 1 "C:\Program Files\CD-adapco\STAR-CCM+11.02.010-R8\star\bin\starccm+.exe" -cpubind -nodeerror: Design STAR-CCM+ simulation completedServer process ended unexpectedly (return code 1)mpirun: Drive is not a network mapped - using local drive.MPI Application rank 0 exited before MPI_Finalize() with status 8 Mattiash helps me figure it out, it works now. Cheerslexi. Share this post Link to post Share on other sites
