Mr. Demitri Economou
how to change default pdf viewer
I have caeses 4.1.2 installed on debian Jessie, running the trinity kde desktop 90% of the time. It seems that the software runs fine, so now i will try to run the tutorials, but clicking on a particular tutorial opens it with gimp. i have a number of pdf viewers, both under gnome and tde, so i woullike to use one of the. obviously Caeses does not check the file associations of the trinity desktop, so i guess there is a config file that needs to be changed. can someone please point to the file and /or the change ?
thanks in advance,
d.
If you cannot make it to associate the correct file extension to the corresponding software, then you can also find the tutorials in the installation directory of CAESES (folder "tutorials").
