Mr. amin ava
Exported model split in two faces
Hi Everyone,
I create a duct in CAESES by sweeping a circle to an ellipse which is made by one face and I export it as iges . When I import it in Gambit, the geometry split in 2 faces and I couldn't merge them to have a unite face. I need to have a duct which is created by just one face because I want to create a structured mesh in Gambit.
What should I do to fix the problem?
I attached the model pictures
Thanks.
Hi Amin,
I checked your file and seems changing the parametrization to "unit speed" for the total contour did the trick.
For both start and end profile curves please try to change the parametrization value from default to unit speed. You can find it if you expand the "general" menu.
Please let me know if you experience any problem.
Ceyhan
  • Upvote 1
