If I understood things correctly then CAESES can read and process VTK formated files.
however I could not make that work with my vtk's or tecplot files.
Since I use the CAESESfree version, is this only availiable in the pro version ?
Or,
 what VTK formats does cases read (legacy, xml ect.)?
Is there a way to diagnose if the file was read, from some log file of sorts ?
Hi Max,
You are right, CAESES can read different kind of VTK formated files (XML, legacy, ...).
Did you try to connect via "File -> Data Connection -> VTK"?
What is the error?
If you could attach a small example of the kind of data to process, I can take a look into it.
Stefan
