Mr. Max Staufer 0 Report post Posted May 31, 2016 If I understood things correctly then CAESES can read and process VTK formated files.however I could not make that work with my vtk's or tecplot files.Since I use the CAESESfree version, is this only availiable in the pro version ? Or, what VTK formats does cases read (legacy, xml ect.)? Is there a way to diagnose if the file was read, from some log file of sorts ? Share this post Link to post Share on other sites
Stefan Wunderlich 6 Report post Posted June 1, 2016 Hi Max, You are right, CAESES can read different kind of VTK formated files (XML, legacy, ...).Did you try to connect via "File -> Data Connection -> VTK"? What is the error? If you could attach a small example of the kind of data to process, I can take a look into it. Cheers,Stefan Share this post Link to post Share on other sites
