Mr. Ale Jah 0 Report post Posted December 28, 2015 Hello, I am trying to add fillet surface to the sample propeller provided with the software (Open Sample -> Blade Design -> Maritime -> propeller).I have read the tutorials dealing with fillet surface and Breps, but I cannot figure out how to apply the methods to the sample propeller. Can you please advise how this can be done ? Thank you in advance for your help. Share this post Link to post Share on other sites
Karsten Wenzke 12 Report post Posted January 4, 2016 Hey Ale Jah, Take a look at the sample propeller Blade and Hub fillet. It is based on the Propeller sample but instead of using the Propeller object which can only be exported as iges and pff.You cannot introduce fillets in the propeller object. You need to use the generic blade surface and create a brep. Which has been done in the Propeller blade and hub fillet sample.If you want a propeller with all blades you can take a look at the attached project. Cheers, KarstenALE_propellerbladewithfillet.fdb Share this post Link to post Share on other sites
Mr. Ale Jah 0 Report post Posted January 6, 2016 Hi Karsten, Thank you very much for your help, very much appreciated.And best wishes for 2016! Cheers, Ale Share this post Link to post Share on other sites
Karsten Wenzke 12 Report post Posted January 8, 2016 You are welcome.Thanks a lot. If you have any further questions do not hesitate to post them. Best wishedKarsten Share this post Link to post Share on other sites
