Sign in to follow this
Mr. Carlos Repolho
Skybackground, Render, animation
Good Morning,
Could you give some hints regarding the configuration skybackground menu or provide some kind of video tutorial.
If a tuturial is not available could you give a short explanation how to positionate the water regarding the ship, my ship appears always to be at the top of the water even after i define the ship position vector.
best regards,
thank you
Hi Carlos,
please find attached a sample project. I usually create an image of the hull and shift it in negative z by the draft value. Thus it is in the water. I don't know how to change the sky-view water level.
I hope it helps.
Matthias
Thanks i will give it a look.
I achelly thought about it but i have the container stack and the bridge dont know if i can shift it also.
best regards
Hi Carlos,
you're right, the in-build screenshot tool seems to have problems with the Skyview. Let me check that! The only solution right now is probably using an external tool. Windows Snipping Tool or >print< and good old Windows Paint :)
I'll keep you up to date.
Matthias
