Hey,
here is an example for the Brep operation: solid from intersections.
solidfromintersectionFor.fdb
This operation creates a solid (right side)from the given inputs (left side).
Hub with the blade trimmed by the shroud.
In this case there are also 2 more solids possible:
1. Just the hub with the blade intersection face.
2. Closed blade trimmed at hub and shroud.
To browse through the different solids use the "Solid to keep" argument.
You can use all surface types and other breps for this operation.
