Jörg 29 Report post Posted March 8, 2013 If you have problems with the menu entries such asmenu entries disappearedmenu entries are colored grey and you cannot access themthen you might have a problem with the configuration files (.cfg). These files control the menu structure and can be found in e.g. "[userName]/AppData/Roaming/friendship/etc" (user application data, depending on the OS, this is the Vista/Win7 path). It is not the "etc" dir located in the installation directory (e.g. "C:\Program Files\FRIENDSHIP-SYSTEMS\Framework\etc"). This might come from crashes (i.e. the cfg-files are not saved properly). Solution: Delete your cfg-files in the folder mentioned above. Alternatively (if you are able to access the file menu): choose file > settings > button "Reset to Factory Settings" CheersJoerg Share this post Link to post Share on other sites
Mr. Ognian Dantchev 0 Report post Posted November 25, 2013 Hi Joerg, This post helped me complete my installation under Ubuntu 12.04 (stadard with Unity), thanks! Most of the menu items (but File and Help) were missing. After deleteing cfg files all of them went completely missing :)But this helped me figure out plugin libraries don't load at all -- CAESES don't like long foder names, with spaces and / or using Cyrillic. Like 'My Documents'.Moved the whole thing to simple/short name folder and now it works just file, all plugins load OK and all menu items are visible. Thanks again,Ognian Share this post Link to post Share on other sites
Jörg 29 Report post Posted November 26, 2013 Hi Ognian, Good to know, thanks for this feedback! CheersJoerg Share this post Link to post Share on other sites
Jörg 29 Report post Posted May 8, 2019 You can also try out to restart CAESES using the "reset to factory settings" menu entry: Share this post Link to post Share on other sites
