Sign in to follow this
pdp.aero
Launching CAESES 5.3 in Ubuntu 22.04
Hi I recently switched to 5.3 and now when I launch CAESES it opens for a second then it gets segmentation fault
I appreciate if you let me know what is the problem. Thank you.
5.2.6 works though
If you have crashes using a custom file dialog (PDF generation or OpenProject) add "-style plastique" to your start script
Fontconfig error: Cannot load default config file: No such file: (null)
CAESES 5.3.3
loading plugin libraries ...
plugbase - ok
plugblade - ok
plugdakota - ok
plugfeature - ok
pluggenericintegration - ok
plugkspline - ok
plugmeta - ok
plugopt - ok
plugoptmo - ok
plugsshrm - ok
plugxffl - ok
shfctrl - ok
initializing types ...
    plugins - ok
    basic object types - ok
    entity types - ok
*** INFO REPORTSERVER : started [port: 12345]
    view types - ok
initializing commands ...
Path override failed for key base::DIR_APP_DICTIONARIES and path '/home/pdp/soft/caeses/CAESES_5.3.3_Linux.x86_64/bin/qtwebengine_dictionaries'
Path override failed for key base::DIR_APP_DICTIONARIES and path '/home/pdp/soft/caeses/CAESES_5.3.3_Linux.x86_64/bin/libexec/qtwebengine_dictionaries'
    all *** INFO DOCUSERVER : started [port: 34709]
 - ok
initializing configuration ...
updating geometry - ok
QImage::scaleWidth: Image is a null image
QOpenGLWidget: Already initialized, setting the format has no effect
/home/pdp/soft/caeses/CAESES_5.3.3_Linux.x86_64/CAESES: line 115: 1344215 Segmentation fault      (core dumped) ${FS_INSTALL_DIR}/bin/CAESES $ARGS "$@"
