Manoj 0 Report post Posted February 7, 2025 Hello all, I'm currently working to connect the FINEMARINE software with the CAESES software to optimize a sample hull model. I don't know where to start and all. I have went through your Q&A session regarding the same field. Kindly give some instructions on 1.Geometry input: Whether it should be meshed and given or else only domain subtracted with hull model would be used How the domain should be imported .,i.e, in what format Which one to be used eiether Hexpressx86_64.exe or finemareinex86_64.exe in Local Application for computation? 2.Input File: Input.txt as cwizard.input What would be the possible input and logics Any other files to be included 3. Result values : output.txt Thanking you in advance, hoping your suggestions would help me to complete my college project Share this post Link to post Share on other sites
Hannes 2 Report post Posted February 10, 2025 Hi Manoj, usually, you start with a working setup that is capable to be run from the command line. This is entirely FM-specific and outside of CAESES. In the current version of CAESES we provide a tutorial on the geometry preparation for FM, based on the Maritime Workflow introduced in CAESES 5.3. Assuming you've got the latest version of CAESES installed, you can find it here: http://localhost:65038/tutorials/maritime/software-connection/fine-marine-pre-processing . This geometry should be exported either as parasolid or as multibody stl. At this point the above-mentioned workflow comes in. Please identify all relevant input files and provide them from the software connector. Define case-specific values by parameters. Put the command you used to run the setup from the command line into "ExecutionSettings|Arguments" (possibly preceded by "bin/bash"). Run the case for one geometry from the software connector and define all relevant result files within the software connector for further post-processing. Hope this helps! Cheers, Hannes 1 Share this post Link to post Share on other sites
Manoj 0 Report post Posted February 12, 2025 Thank you for your help. @Hannes I can't able to open and see the link you(HANNES) gave in the above post. Will u help by sharing in any other way. Share this post Link to post Share on other sites
Hedi Boettcher 7 Report post Posted February 14, 2025 Hi Manoj, You can access the CAESES documentation in the Help section in the software CAESES. In the documentation you will find the "Fine Marine Pre-Processing" tutorial under Tutorials > Maritime > Software Connection > Fine Marine Pre-Processing. Cheers, Hedi 1 Share this post Link to post Share on other sites
Manoj 0 Report post Posted February 15, 2025 Thank you for your help, @Hedi Boettcher. Sad thing is I wasn't able to download is the above tutorial project 😞.But I have manged to create domain and did boolean and successfully generated .stl file. For now I'm stuck at this part as I don't know how to import (whether to run using scripts or by batch mode with usage of [.iec],[.sim],[.bat],[.dat],.[run]) and get output feeds from the Finemarine software. Share this post Link to post Share on other sites
