Mr. Chang Xie
CAESES outputs NAPA-format hull line file
Good day.
For ship engineer, hull line need to be imported into NAPA for ship stability calculation and subsequent construction. So NAPA-format hull line file is important for ship engineer to edit in NAPA.
I want to export NAPA-format hull line file (see attached) from CAESES based on a hull surface (Brep surface or Trimesh sufface), which is a txt file, not iges or stl.
Have you developed an output feature yet? Can you provide me with a reference?
Thank you.
KCS_hull_SVA_Napa.txt
Hi there,
a few users have successfully implemented such features with varying degree of complexity. If you are familiar with NAPA definitions you can easily write a custom export in CAESES. However, there is no solution readily available in CAESES.
Kind regards,
Heinrich
