yuvraj 0 Report post Posted November 25, 2024 Hello Caeses Team I am trying to make surrogate model by importing the result pool, but when I run the optimization (RSMO) on it , it gives me points to test by CFD run , but I need data from the response surface, how to tackle this problem. Eagerly waiting for the reply Regards Yuvraj Share this post Link to post Share on other sites
Mr. Heinrich von Zadow 12 Report post Posted November 25, 2024 Hi Yuvraj, if everything else is set up correctly, you should be able to abort the CFD run and just take a look at the 'finaldata' file that is written by Dakota. This contains the predicted optimal design (or Pareto set, if multi-objective) and the predicted evaluations. Kind regards, Heinrich Share this post Link to post Share on other sites
