Mr. Mattia Brenner 6 Report post Posted May 26, 2014 ----------- Chemical & Process Industry --------------- This is a META-thread, which helps you to keep track of all posts relevant to Chemical & Process Industry. - The first post should contain links to all relevant threads. It is re-edited regularly.- I try to keep this META up to date. However, I don't always catch everything, so please post links to any threads you think should be here. I will add them to the existing ones in the first post and periodically clean all other post from this thread. Thanks,Mattia --------------------------------------------------------------------- Modeling of a top-entry mixer for highly viscous and sensitive fluids Modeling of a heat exchanger Modeling of a central mixer with asymmetric blade shape Parametric modeling of a mixing section for plastic injection molding Modeling of a helical impeller Share this post Link to post Share on other sites
