Yukai 0 Report post Posted August 1, 2024 HI! After I manually modify the CSV file generated after optimization, am I no longer able to import CAESES as a solution pool? Because the file used to calculate the objective function was not modified, the result data after optimization became the same, so the CSV was rewritten after optimization (I calculated the objective function using a Python file written by myself) Thanks for your help!!! Best Regards YuKai Share this post Link to post Share on other sites
Mr. Heinrich von Zadow 12 Report post Posted August 1, 2024 Hi Yukai, you can import the csv file via "Import Result Pool" in the optimization workspace to use it as a database for subsequent optimizations. Cheers, Heinrich Share this post Link to post Share on other sites
