Carlos Simões 0 Report post Posted April 23, 2023 Hello, I'm using a tutorial on my project and I'm struggling to understand some of the commands. I've attached a printscreen of the command I'm supposed to use when generating a point. I'm supposed to get a point on the FOSextended curve, that matches the height given by the function zMid. The presented command for Tp doesn't work. What's wrong with it? Best regards, Carlos Share this post Link to post Share on other sites
Ceyhan Erdem 14 Report post Posted April 24, 2023 Hi Carlos, It is quite difficult to see what is written for the input location corresponding to "Tp" Basically tp is a value varying from 0 to 1 and it defines the parametric location within the curve. 0 being the start and 1 the end. I guess you have used a combination of ft and fv ending up having the parametric value. I can see a value is printed over the command which is the result. Can you please let me know what makes you think the command is not working? Do you think it is providing an incorrect value? If so, can you please be more specific in order to understand? Cheers Ceyhan Share this post Link to post Share on other sites
