Rizuan Razali 0 Report post Posted September 4, 2022 Greeting everyone, The geometry that I want to export to IGES is the yellow one, which is the optimum geometry. The silver colour is the initial geometry. It was supposed to look like that when I did the comparison. However, when I export optimum geometry and do the comparison in CAD Rhinoceros, the geometry has changed. It became like this: I hope you guys can help me figure out how to export optimum geometry correctly and how to solve this problem. Thank you. best regard, Rizuan Share this post Link to post Share on other sites
Mr. Claus Abt 14 Report post Posted September 5, 2022 Hi Rizuan, If you select the modified hull in the object tree, you should export only this object. There should not be any modification to the hull during the export. In case we have to take a closer look, please open a ticket in the helpdesk and send us the project file. Best Regards Claus Share this post Link to post Share on other sites
Mr. Claus Abt 14 Report post Posted September 5, 2022 Your modification is so small, that you can simply not see much .... Share this post Link to post Share on other sites
Rizuan Razali 0 Report post Posted September 7, 2022 Thank you for your replies, Mr. Claus. I will take note of that. Share this post Link to post Share on other sites
Rizuan Razali 0 Report post Posted September 12, 2022 Hello, Mr. Claus. May I ask you to please explain how to draw those lines on the buttocks exactly as you have shown above? I've already looked for tutorials. But I couldn't find anything about it. I can only do curve sectional area. I'm hoping you can assist me with this issue. Many thanks. Share this post Link to post Share on other sites
Mr. Claus Abt 14 Report post Posted September 27, 2022 Use the section visualization in the display options. Share this post Link to post Share on other sites
