Mr. Matthias Krueger 0 Report post Posted December 19, 2013 Hello, after the calculation and optimization with "EnsembleInvestigation" I'm exporting a gnuplot plot (.png). It is visible in the picutureViewer for the different designs. But I would like to see it together with the results and screenshot in the Documentation Browser. So I can see it all together on one page and don't have to swtich.Is there a possibility? Thanks for you help. Matthias Share this post Link to post Share on other sites
Stefan Wunderlich 6 Report post Posted December 19, 2013 Hi Matthias, Currently, only a workaround is possible. We might include a more user friendly version of this in a later release ;-) I created a simple feature-definition that would insert the image at the beginning of the design-documentation AddImageToDesignDocu.fdf.You might extend it, it is very simple.You would then create a feature instance and set the name of the image and the computation.In the design engine, add a postprocessing command like "[myFeature.run()]" to execute the feature after each finished design (you have to expand "Design Pre/Postprocessing"). You can create more instances if you have more than one image (postprocessing command: [f1.run(), f2.run(), ...]) or extend the feature definition. I hope that helps. Cheers,Stefan 1 Share this post Link to post Share on other sites
