Hello all,
I've created a feature do calculate the Bereau Veritas design.
Now I wanna plot it using a panelMesh.
I tryed to used a unstructuredPanelMesh, using the command:
.setData(FVector3Series point data, FUnsignedSeries panel data, FListOf<FDoubleSeries> metaData, FListOf<FString> meta data names).
My question is: what should I use for the FUnsignedSeries panel data? I couldn't realise it by myself.
Thanks a lot,
Humberto
Hi Humberto,
I understand, this us not self explaining.
Basically the panelmesh needs a list of points and a series of point indexes that define the panels. Additionally you could have multiple values fur each point (meta data) which I skip for simplicity.
So if you have four points in your pointlist (ordered in rows), you could define a four sided panel in the form of [4, 0, 1, 3, 2] where the first "4" defines a four sided panel.
To define 2 triangles you could have [3, 0, 1, 2, 3, 2, 3, 2].
I think it is easy to understand if you see it, so I attached a sample feature that creates a simple panelmesh (I am open to further questions).
Stefan
mesh_test.fdf
