Armagan 0 Report post Posted August 24, 2021 Hello, I designed a NREL S826. I exported all points to Caeses. But I could not create surface. Attached I am sending my model. Could you help me to solve my problem. Thank you in advance Best Regards NREL826_Armagan.fdbc Share this post Link to post Share on other sites
Ceyhan Erdem 14 Report post Posted August 27, 2021 Hi Armagan, Sorry for the late respond. Please check the feature definition you use for the "Curve Engine" definition. The feature definition called "ProfileRead" serves only to read a point cloud and provide you an interpolation curve as a result. You are not changing anything afterwards. With respect to the code you are trying to create a surface out of a set of multiple profiles located at the same location. Although you have arguments like camber, camber position, pitch and path, it seems like you are using none. I highly recommend you to check the basic CAESES tutorials with regards to Meta Surface creation and Curve Engine. Cheers Ceyhan Share this post Link to post Share on other sites
