Sign in to follow this
Armagan
Wing Modeling
Hello,
I designed a NREL S826. I exported all points to Caeses. But I could not create surface. Attached I am sending my model. Could you help me to solve my problem.
Thank you in advance
Best Regards
NREL826_Armagan.fdbc
Hi Armagan,
Sorry for the late respond.
Please check the feature definition you use for the "Curve Engine" definition.
The feature definition called "ProfileRead" serves only to read a point cloud and provide you an interpolation curve as a result.
You are not changing anything afterwards. With respect to the code you are trying to create a surface out of a set of multiple profiles located at the same location.
Although you have arguments like camber, camber position, pitch and path, it seems like you are using none.
I highly recommend you to check the basic CAESES tutorials with regards to Meta Surface creation and Curve Engine.
Ceyhan
