Mr. Toni Klemm
Manipulate path of result files
Hello,
How it is possible to change the path of a result file which is configured in a computation?
In case of Fine/Turbo my result files are in the computation directory in subfolders. (comp_dir/folder1/folder2/result_file.txt)
At the moment Framework could not find these files.
Toni
Hi Toni,
You can simply write the sub-path before the file name.
I guess this screenshot explains better what I mean:
So, if there is just the name of the file it has to exist in the folder of the computation (The folder which has the same name as the computation).
From there you can go deeper into a sub folder structure.
Ben
Hi Toni,
doubleclick your result value file in the Software Connector. You can then use the input field "Subfolder" to solve your problem, see the screenshot.
Jan
