Mr. Chien Nguyen 0 Report post Posted March 6, 2021 Hello, Is this possible to create variable fillet at propeller root? Normally, at the propeller root there are two fillet radius parameter (one at the pitch side and the other at the back side) For the 1 radius fillet, I can do it well with brep edge fillet. I tried to create variable fillet with surface mapping but it does not work! Thank you Share this post Link to post Share on other sites
Mr. Heinrich von Zadow 12 Report post Posted March 8, 2021 Dear Chien, yes, this is possible, although a bit tricky at times because you will need a very clean model to begin with... The result would look something like this: The corresponding settings here where as follows: Cheers, Heinrich Share this post Link to post Share on other sites
Mr. Chien Nguyen 0 Report post Posted March 10, 2021 Dear Heinrich Thank you so much for your answer. But I tried with the sample propeller file in Caeses, I still did not succeed to create the fillet! is this possible that you can upload for your file for my reference ? Share this post Link to post Share on other sites
Mr. Heinrich von Zadow 12 Report post Posted March 10, 2021 Dear Chien, why don't you upload yours? Probably even more helpful for you... Cheers, Heinrich Share this post Link to post Share on other sites
Mr. Paulo Macedo__0002 2 Report post Posted March 10, 2021 Example project attached. varFillet.cdb Share this post Link to post Share on other sites
Mr. Heinrich von Zadow 12 Report post Posted March 10, 2021 Here we go, thanks Paulo! Share this post Link to post Share on other sites
Mr. Chien Nguyen 0 Report post Posted March 11, 2021 Dear Heinrich and Paulo Thanks so much for your answer, I upload my project here. if i just create 1 fillet radius (60) with fillet edge, it works very well. Now I would like to create one fillet radius 50 at Pitch side and 60 at Back side. I tried but it did not work Beside, could you explain the meaning of position value, I understood that it should be from 0 to 1, but what is the position of 0 and 1 Thank you so much propeller.cdbc Share this post Link to post Share on other sites
Mr. Heinrich von Zadow 12 Report post Posted March 15, 2021 Dear Chien, the position value is parametric. I modified the input surfaces for your blade such that now (0=start, 1=end and anything in between depends on the internal parametrization of your input surfaces, i.e. knot vector, control points, degree, etc...). Practically, in most cases you would need to know your leading edge position (now 0.5) and you can simply find out which side is suction and pressure by trial and error. I recommend that you move the hub seam out of the way (by adding 180° to the start and end of the hub contour). Also the trailing edge doesn't look ideal. I increased the tangent factors of the underlying fillet surface as a simple fix: Not sure if it makes a difference in this case, but please note, that I used the new 5.0.4 release. Unfortunately I couldn't get the variable fillet to work right away, either. I will try to find some time to take a closer look. Cheers, Heinrich propeller.cdbc Share this post Link to post Share on other sites
Mr. Chien Nguyen 0 Report post Posted March 18, 2021 On 3/15/2021 at 2:17 PM, Mr. Heinrich von Zadow said: Dear Chien, the position value is parametric. I modified the input surfaces for your blade such that now (0=start, 1=end and anything in between depends on the internal parametrization of your input surfaces, i.e. knot vector, control points, degree, etc...). Practically, in most cases you would need to know your leading edge position (now 0.5) and you can simply find out which side is suction and pressure by trial and error. I recommend that you move the hub seam out of the way (by adding 180° to the start and end of the hub contour). Also the trailing edge doesn't look ideal. I increased the tangent factors of the underlying fillet surface as a simple fix: Not sure if it makes a difference in this case, but please note, that I used the new 5.0.4 release. Unfortunately I couldn't get the variable fillet to work right away, either. I will try to find some time to take a closer look. Cheers, Heinrich propeller.cdbc 1.17 MB · 0 downloads Dear Heinrich Thanks for your reply and your correction. I will try to play with it to get the variable fillet and let you know if it works Share this post Link to post Share on other sites
