Armagan 0 Report post Posted December 7, 2020 Hello, I would like to export .step file from Caeses to meshing in Gridpro. But, I could not use model which is exported from Caeses in Gridpro due to low quality display. I have tried to change display options of model. Is there another way to get more qualified model as .step file from Caeses. Thank you in advance Share this post Link to post Share on other sites
ConnieR 0 Report post Posted June 2, 2021 On 12/7/2020 at 12:56 PM, Armagan said: Hello, I would like to export .step file from Caeses to meshing in Gridpro. But, I could not use model which is exported from Caeses in Gridpro due to low quality display. I have tried to change display options of model. Is there another way to get more qualified model as .step file from Caeses. Thank you in advance Upon selecting the formats, it opens a file dialog box in the working directory from which you can select the file name to be imported. The file dialog box would be filtered automatically for the selected file format. Export option allows you to export various surface and grid formats from GridPro. https://tutuappx.com/ Vidmate Share this post Link to post Share on other sites
