Mr. Roy Powell
error message: GL_UNDERFLOW [1101]
Could someone please help with the following issue?
After Installing the downloaded 32-bit file and starting the application, this error message is displayed:
 GL_UNDERFLOW [1101]
The startup-process is then halted and the application does not work.
No error messages were received during installation.
I am running windows 7.
Thanks
Thank you Konrad and Anne for your replies.
I did check the time settings on my laptop and corrected them to match my time-zone.
After doing this, the application did start up and run. I was able to shut down the application and start it again too.
However, right now the same error message appears and the application fails to run.
The install is on a stand-alone laptop without network connectivity.
Could you please help me out again?
Thanks,
Roy
Could you please send the startup logfile from a failed attempt to start the software. Please see this forum post for how to find it: http://www.friendship-systems.com/forum/index.php?/topic/28-how-do-i-handle-error-messages-when-starting-the-framework-or-caeses/
Note that you will need to zip the html file since the forum does not allow html files as direct attachments.
Dear Roy,
There still seems to be a problem with your time settings. The last entries in your logfile have a timestamp that is in the future (Aug 7th, 12 pm) - you are located in the Netherlands, right?
Please verify again, that your time settings are correct. Some initialization routines of CAESES are dependent on a correct setting.
Best regards
Arne
Dear Arne,
Thank you for your help. After deleting all files and folders in the appdata/friendship/ folder, the application ran perfectly. My current time-zonen is singapore so not The Netherlands. However I am from The Netherlands. The download and installation of your software was done on my laptop in Singapore time zone. Again thank you for your help.
Kind regards,
Roy
