Hey,
surfaces are defined by the parameters U and V the minimum is 0 and the maximum 1.
0 is equal to the starting of the surface and 1 is equal to the ending of the surface.
There are four different ways showing the U-V-Orientation of a surface in CAESES/FFW.
  1. highlight a surface and in the ObjectEditor in the categorie  Display Options click on this button post-41-0-09705200-1375698955.png.
  2. right-click the surface object in the ObjectTree and select 'Show U-V-Orientation'
  3. right-click the surface in the 3DViewer and select 'Show U-V-Orientation'
  4. highlight the surface and type this command in the Console: mycurve.showOrigin(1) to show the orientation and mycurve.showOrigin(0) for not showing the orientation
Best Regards,
Karsten
I moved your question here, because it is more related to this topic.
You have two possibilities to change the domain:
A: Add an Operation to your surface (Operation -> More -> Domain)
B: Create an ImageSurface of your NURBS surface.
To reverse the direction, simply change from [0,1] to [1,0]. You can also swap the domain (u->v / v->u). But be careful with to order of doing it.
Carl
