if you want to create a periodic mesh based on one shape, please find therefore the attached example . This feature is often used when propeller have to be exported to stl files for a viscous calculation.
The procedure is as follows:
1. create all need surfaces
2. for surface visualization put all surfaces into a ImageSurfaceGroup and use this as source of  the PeriodicImages feature. This feature can be found in the transformation tap.
3. create a TriMesh with all needed surfaces
4. Use this TriMesh as a source for the feature definition periodicmesh
best regards
Carsten
periodic.fdb
